Hi all, not sure if this is the right forum or not, hopefully a Moderator could move if not.
In September last year prior to purchasing our property we had a Homebuyers report completed which mentioned that there was some penetrating dampness on the chimney breast caused by various issues within the chimney stack.
Because of this, we took the decision to completely remove the chimney stack to below the roofline and have the roof "made good" and tiled over in that area. This work was completed at the end of July, however the damp spots largely still have not cleared away and after periods of rain are probably about 80% as bad as they were before the stack was removed. The damp spots are limited solely to the chimney breast on the upper floor.
I do not believe that there is any issue with the workmanship of the new roof as I have placed sheets of cardboard at the top of the chimney in the loft for a couple of days where it opens into the loft area, and they are dry even after rain, and the wall getting worse.
Could anyone recommend what type of firm would be best to identify what exactly is my problem? Is a standard RICS surveyor likely to be able to help or do I need a buildings engineer?
