There are until you try to order them - tried all the links - no stock and no indication of when they will be available.Google 10mm pipe Covers not sleeves, there are loads of them
Thanks - just checking they are suitable for 10 mm as no info on sizehttps://www.toolstation.com/talon-s...BqJRRUuUJ1Los6ZsJ8YApoodNl6vvMgBoCwR8QAvD_BwE
10 packs available for delivery and 1 for collection , just put your post code into that link and you will get information from your local stockists
Tried that - looks awfulWhy not put 15mm covers on 10 mm pipes? No one will know the difference as the gap is invisible.
Good idea, but they are in bathroom and kitchen under laminate flooring - was done before I moved inIf the valve is 10mm entry and you use a15mm sleeve it can be difficult to stop it looking wonky.
To the op I'd be tempted to replace the legs with a short length of copper or even speedfit 10mm is white and looks ok but you might struggle to get less than a 25m roll of it.
Might try that - thanksWhite tape perhaps?
