The valve was already fully anti clockwise and can’t go any further. Now I have turned the heating down to 20 and turned the radiators back on, the radiator in question is luke warm at the top and cold at the bottom.Chemical Flush
This may be a bit daft, but weird things get missed. Try to remove the valve cap from the other valve. You may need a small screwdriver, or if no screw visible on top it pulls off. Once off, use an adjustable spanner and turn the spindle fully ANTI clockwise. Count the number f 1/2 turns until it stops. Try heating. Report back![]()
Yes! I did lots of research before I spent over £2000. But I hadn’t thought of contacting Which.Never heard of HUG, but did a quick google and saw no issues. However, they are part of Which? trusted traders scheme. Did yiu know this? You may wish to look int how they can help. It would be interesting for us to know how that goes.
The Which? Trusted Traders code of conduct | Which?
Home Utility Group Limited - Heating contractors in Leeds, West Yorkshire
So an old combi Baxi boiler came out (not sure of model but I do know it was smaller in litre capacity) and a Worcester Bosch 30i went in. Just a straight change, nothing else altered.What exactly was fitted? Just a boiler changeover, or further works. There are obligations on aninstaller to comply with part L, did they do any pipework alterations?
Stupid things do occur. Many years ago, I gave a guy I knew a chance to work with me. He wasn't a plumber, but wanted to work. Hr told me that he had helped his plumber dad in the past, so had some basic skills. When we had finished, one radiator was very hard to get working and on a small house it shouldnt be difficult. Anyway, it turned out that he had nailed the CENTRE of a board (any pro knows that you nail towards the edge of the board and run pipes down the middle) . The nail was presenting a massive resistance to the flow.
So, as per Terry's query, what was taken out and what went in? Could a pipe be nailed. Did they not test the heating before leaving?
Contacting which ???? you would be better contacting a distant relative at seanceYes! I did lots of research before I spent over £2000. But I hadn’t thought of contacting Which.
Hahaha!Contacting which ???? you would be better contacting a distant relative at seance
Should I just give up on HUG and find a local plumber? I haven’t yet paid HUG for the unnecessary trv etc that was changed on last visit...If I was there,I would be turning off valves, disconnect and run water into a container, just to see flow. Quick swap of valves and try again. Just to eliminate valves from issue. I would bet against sludge causing this, TBH. But then, if I was installer, I would have returned to sort out, not to sell another job.
Trouble is, a lot of installers seem to work on shoestrings so have nothing in reserve.
