Sheet vinyl and ply
18 Oct 2006
Buckinghamshire
Daughter wants sheet vinyl in her cloakroom
Concrete (beam and block with skim) floor is pretty flat and smooth, room is about 2 m sq.
Am considering using ply underneath to lift the surface and probably warm the surface.
while I could screw it down would contact adhesive do?
for a small cloakroom over a smooth finished B&B floor i would leave as is, and then i would simply loose lay the sheet vinyl, and use perimeter stick down D/S tape after the vinyl had settled.
