Twin flue pipes
Status
Not open for further replies.
Keston boilers are not B type flue approved, so two pipes have to be run to outside, even if the basement is ventilated enough.
Navien say their combis can take the air for twin pipe setups from a well ventilated basement room.
As mentioned above it would essentially be a b22/23 chimney system. Check manufacturers instructions/data badge for allowable applications. Simple as that.
I suggest you contact each UK supplier/manufacturer individually and ask for their twin pipe installation instructions .
The replies you've received so far obviously don't match your required multiple guess quiz sheet answers.
I asked Do many domestic makers state the air has to come from the outside only, via a pipe?
I didn't get any constructive replies,
Yes you did
as this solution was out of the experience of all on the thread.
No it wasn't
But a lot of useless know-it-all noise was forthcoming as usual.
From you it was, as usual, yes.
Thread Locked.
Status
