D
Deleted member 267285
When you mean partially combined does that mean rainwater with foul water ?
Yes. It might be worth checking out.
What benefit would that give - allowing to use a rainwater drain for the waste to connect to ?Yes. It might be worth checking out.
Are you sure your foul drain isn’t on a back drop shaft to get to the 3.5mtr depth? If it is you could connect in at the higher level somewhere.
Not sure how I could tell, there isn't any inspection chambers before the manhole.
Nothing else in manhole apart from the bottom runs looking like this, the top pipe points towards the soil stack in the house.There would be a bit of 4” pipe higher up the manhole wall like this:
The arrows show how the pipes would run.
