Best wired alarm system
21 Aug 2019
Hi everyone I brought a house currently has a wired adt alarm system with Honeywell controller in hallway and bell box front and back and sensors in rooms, the previous owner used it as a monitored alarm payed 30 pounds per month, I don’t use it but wondered if it can be upgraded or modernised to a better system which can be controlled buy smartphone, also which are the best home alarm wired systems thank you
There is lots of choice out there, has been covered many times.
how many sensors do you have that are currently hard wired?
You doing the installation yourself?
Speak to galaxy guy ....depending on what panel you have ....selfmon maybe a cheap option
Hi second that. Refurbishing a flat at the moment that will be rented out and looking at installing an alarm system. Will be 3 pir sensors 2 door sensors and will be doing it myself. Any recommendations please?
I normally install the Honeywell but let me know if there’s something better out there please
Check to see which Honeywell panel you have by looking at the label on the main control panel, which will be a metal box normally in a cupboard with the electric meter / consumer unit. If it's a Galaxy G2-12/20, there are options to add Ethernet, or swap the controls for a Galaxy Flex control panel with Ethernet module while using all the existing wiring/sensors/sounders.
Cheapest product is not always the cheapest option ....lowest panel i would fit is a pyronix euromini
