Gap filling gripper adhesive
  • Thread starter Thread starter bsr
  • Start date Start date
bsr
5 Aug 2008
Gloucestershire
Hello
Please recommend a gap filling adhesive to glue down gripper. It needs to cover 0 to 5mm holes in the screed from pulling up the old gripper, and where some of the self levelling has cracked.
Is standard no more nails ok or do I need something special? No time pressure, carpet fitter is not coming for 2 weeks so I don't need a fast cure.
My foam gun is knackered so ideally looking for something I can apply with a sealant gun.
Fix-all is ideal , carpet fitters often carry hot glue gun which takes 30secs to cure.
  • Thanks
Reactions: bsr
Thanks All. I've seen flexy fix recommended on a carpet fitters forum but it's not easy to get hold of. I'll use the fix all and let it set for a few days.
Update, I used the fix all and it does work really well, I think it will take off the self levelling compound when it comes off!
Hard work to use though, need to squeeze hard to get it out of the tube, it's stiff stuff.
Or... you need a proper gun, a Cox for less than £20 will last you a lifetime and you'll never swear at a glue gun again.
If you can wait gripfill will be perfect.
That would seem to be the right thing to use as a
' Gap filling gripper adhesive ', I haven't used it on a gripper but it fills gaps and adheres as the name implies.
