- Joined
- 1 Jan 2020
- Messages
- 3
- Reaction score
- 0
- Country
We had a new en suite with shower fitted as part of a refurb last year. We're a lower ground/basement flat in a Victorian conversion and this 'new' room is basically our old bathroom annexed off. Everything was replastered and/or fitted 4-8 weeks before the tiling took place.
Since then we have had two tiling problems that need to be fixed.
First, a tile in the bottom corner of the shower has started to pull away from the wall. It is an internal wall where it meets the external wall, and in the few months since this happened a vertical crack has started running up the tiles above. It looks like movement in the wall itself.
https://drive.google.com/file/d/1zXCERBOBbI0RzD6j2LIL7_kl7MW1XzTi/view?usp=sharing
It's a load bearing wall and there is a brick wall/pillar behind the crack. With wood behind the rest of the wall in the shower area.
https://drive.google.com/file/d/1gBKgReTx_FqaMZzsFnVCxPjmzVbS28mw/view?usp=sharing
Second, the tiling on the adjacent wall has started to come away from the ground up along the trim edging.
https://drive.google.com/file/d/13L9dIw8RzS7BObNb0SqVPSUcLGQendRp/view?usp=sharing
I know the main bathroom was float and set, but not 100% sure on this room as I only got one photo at end of day and didn't see the tiler in action here.
https://drive.google.com/file/d/1rbWwFj4UladnbI3aDlhF8S4l5DGGN_Gd/view?usp=sharing
The grout was Mapei flexi, adhesive was Mapei Keraflex Maxi S1. As far as I am aware, the boards were fitted with Gyproc Driwall adhesive.
Due to lack of completion on other snagging works, I am not expecting the original builder to make good on this and they are no longer responding to queries and requests, but we still have the retainer so won’t be out of pocket (hopefully). Any advice on the first point in particular would be helpful as I don't want to retile it for the same thing to happen again. But also keen to know if/how the two issues are connected.
Our main bathroom is totally fine, it's just the shower area in the en suite.
