- Joined
- 13 Dec 2019
- Messages
- 1
- Reaction score
- 1
- Country
Matthew you need to allow two weeks for thermostat to learn. After learning preriod it should work as a charm. Your posts are from a month ago so probably you have already figured this out.
I have spoken to Villaint on number of times but TBH they have not been much help other to say we have a well insulated house.
This means the controls look first at the user set room temperature, then the controls look at the actual room temperature. The controls will then increase or decrease the boiler flow temperature in the most efficient way possible to reach the desired set point. As the set point is being reached the flow temperature to the radiators will reduce as the boiler modulates down to match the heat loss of the property while still maintaining the set point.
As an experiment, we waited for the boiler to fire up and then increased the requested room temperature by 5°C to see what would happen. This actually increased the requested flow temperature considerably. When we turned the temperature back down again, the boiler turned off.
This shows the vSmart is capable of changing the requested flow temperature while the boiler's running.
I think the 'smart' is that it trims the boilers output to the requirement for heat - it knows the room temp, it has an idea of heat loss, so it knows at what level to run the boiler so it just hits the need for heat without over run..Obviously it’s not that Smart.
Your problem sounds similar to what we experienced until Vaillant replaced the whole vSmart kit (i.e. the wiring control centre, communication unit and room thermostat) under warranty at the end of 2019.My greetings from far away (It is Ukraine!)
I have a question to Matthew B, since you seem to have been experienced in the vSmart matter.
My problem looks very similar to that of yours. So, let's start with the equipment, hardware, and software and then work up to the problem.
In July last year, the Vaillant Officials installed Vaillant ecoTEC pro VUW INT 286 /5 -3-H operated by the eRelax. The smart system is supposed to modulate the boiler's power according to the temperature outside.
Just as in your case, I started to question the "smart" feature of my system when cold weather came. Whatever the outside temperature was the boiler's flow temperature always reached up the maximum. The official service advised me to manually set the heating curve at 1.5. I did so and the boiler stopped operating at a maximum flow temperature. It began to analyze the outside temperature to adjust the flow temperature in order to maintain the desired inside temperature. However, somehow I feel it doesn't work as it should, since setting the heat curve manually doesn't make any sense! What part does the "smart" system play in it?
The officials also told me that 1.5 heat curve is the most efficient setting for my region, but I can play with it for the sake of experiment. So, here is the most important thing. When I let the eRelax automatically regulate the heat curve in the app, it snaps back to its misbehavior. Whatever the heat curve the "smart" system sets the boiler's flow temperature is always at the maximum level! Here I come to the question:
Matthew B., is the heat curve set in your system or does it vary?
Setting the heat curve doesn't make sense, because the heat loss depends not only on the outside temperature but also on the desired temperature inside the house.
My guess is that the "smart" system should adjust the heat curve itself to ensure the most efficient gas consumption!
