Stumbled across this forum while searching for a query I have around my boiler.
(Sorry for the long post)
I have a Worcester Bosch Heatslave 20/25, when it was installed (about 15 years ago), the plumber didn't fit a room stat. The rads have thermostat valves fitted, apart from the bathroom one, I was told there had to be one rad without, and was also told the stats would control the boiler.
I will be honest and never really thought about it before. Over the years I have been questioning myself over this, do the radiator stats actually control when the boiler kicks in?
I am thinking this because the boiler kicks in even when the radiators are still pretty hot.
I am not sure if my logic is correct, but here is my thoughts, please correct me if I am wrong..
The hot water tank in the boiler is controlled by a thermostat?
When that water drops below a certain temperature, the boiler kicks in to heat it back up?
If there is demand for heating, the water is pumped around the system until the hot water returns to tank at the required temperature?
The stats on radiators open/close when the water in the radiators reach the required temperature?
If all radiators are closed, the hot water return is quicker, turning the boiler off quicker?
Therefore, the boiler is controlled by the temperature in the internal water tank?
If all of that is more or less how it works, would the following be correct?
My boiler is in the garage, no insulation, so is pretty much the same temperature as outside. If the boiler on/off is controlled by the temperature of the water in the internal tank, with the boiler being where it is the water will cool down quicker at this time of year, meaning the demand for heating will be more frequent, resulting in the boiler sending hot water around the system when it isn't needed.
Again, sorry for the long post, it is just that I am one of those people to like to understand how things work .... haha
So, after all that, the actual question I am wondering.
Can I get a room stat fitted?
If I can fit a room stat, will that stop the boiler sending hot water around the system when it isn't required?
Also, how would I go about fitting a room stat?
