- Joined
- 26 Nov 2016
- Messages
- 21
- Reaction score
- 0
- Country
After I flushed my system recently and replaced a couple of the TRVs, I struggled to re-balance it. There were 2 rads which wouldn't warm up for ages after the rest. I had been unaware that my system would need re balancing. There must have been some serious crud in the pipes.
I learned on this forum that even TRV-equipped installations need balancing. The reason is still a bit fuzzy, but I think that basically if one of the radiators has as a low flow, due to blockages, air, pipe bends, or has a low incoming temperature and therefore doesn't heat up due to being far from the boiler, then one or more of the other TRVs has to close in order to increase the flow and incoming temperature. So, basically, some rooms will heat up while others remain cold until the first are up to temperature.
Anyway, that's not the point. In balancing my radiators, I've created a set of WiFi networked differential thermometers. I can see the flow and return temperatures of each of a number of radiators. monitoring this as the system is switched on tells me which lockshield valves to adjust. And, incidentally, if the TRVs are on the flow or return.
My setup can only do 3 radiators at a time presently, so there was a bit of jiggling involved in tuning my 12 radiators but the system could be extended to cover a dozen radiators for not a great deal of hardware cost. If I thought there was any value in it, I would also make the software a little more friendly.
For me, it was a fun toy. It seems a shame to dismantle it. Would such a thing be of any use to plumbers? Does the system have any commercial potential? Importantly, am I misguided in my understanding of the requirement to balance TRV-controlled radiators?
