Radiator Size - Should I go larger then calculators suggest?
15 Jul 2018
I have the same radiators and if i hadn't gone over spec i would've been cold.
They don't work as well as standard panel radiators, so go with the highest btu you can.
Classic case of 'form over function'
Ever wondered why large ("ugly") cast iron radiators seemed to work yet modern ("stylish') compact units seem to struggle
Thanks for your input. Do you have the same size?
I normally go 50% bigger - most radiator calculators (especially ones that use old fashioned BTU rather than modern kW) tend to use flow and return temperatures that are too high for modern systems. Calculate based on 70°C flow / 50°C return for best efficiency
No, i have a 1400mm.
Accordingly to btu i needed a 1000mm but it wouldn't have been enough.
Those radiators get very hot, but the heat output is nowhere near the standard steel panel radiators.
