I am currently setting out containment and back boxes in our house ready for a rewire. At the same time i would like to run for a home network to increase the broadband set up around the house. The wifi isn't great.
I would like a hard wired ethernet point in each room maybe with 3 or 4 to the main tv room. Is the correct a sensible system and how i should run it.
I was thinking of using the loft space as the main routing area;
1) Install single gang metal back box to each room
2) Run Cat6 cable from each point to the loft
3) Have a patch panel in the loft that each of the cables plugs in to
4) Have an ethernet point located next to my BT point where the providers router is located
5) Plug router into ethernet point to give a feed to the panel in the loft
6) Panel in loft then distributes to each point within each room
Is this how it works? I am trying to understand how the system works so could be completely wrong in what i have in my head!
I will also be installing CCTV so would these also be routed to the loft space?
