As I said, they are (and, I think, have always been) 'rated' at "13A per socket outlet" - but, as I said, even their Technical Support people could not tell me for certain what that means. However, as per post#9 above, it is MK who (at some point in the past) said that when total (continuous) current rises above 19.5A "Increasing the load slightly will begin to cause heat and mechanical stresses on the components in a relatively short period."I thought I read on here they were likely to be rated at 13A x2
As I've also said, despite the fact that such is a commonly held belief (quite probably based on the fact that the BS1363 test is carried out with 20A), I can't recall ever having seen a double socket, of any make, that says that it is "rated" at 20A - have you ever seen that?... unlike other brands which were 20A
