I've fitted laminate worktops in my kitchen, and did some investigation into methods to stick the edging strip before I did it. As the worktops are gloss (yes, they will scratch!) the PVA and iron method wasn't recommended as the heat can ruin the finish. With several linear metres to be done, I wanted to avoid the mess of contact adhesive so I tried the Unika edging tape.
I've found that whilst the glue on the tape sticks wonderfully to the edging strip (ABS plastic) it doesn't stick so well to the chipboard core of the worktop. I've sanded, blown out the dust, shaved back any point bits with a razor, and it still won't stick well. I wonder if priming the chipboard will give the tape something better to stick to. Any ideas? Unika's technical helpline were not very useful!
