Hi All,
I have a project building a hall for my local Scouts. The internal cavity wall leaf will be paint grade blocks and rather than using the standard "holding down straps" every 2m on the inside face, which would be on show. I was thinking about other methods of construction. Could I bolt the 100x50mm plate down into the blockwork or use resin bolts vertically into the top course of blocks?
Holding down straps are 1000-1200mm long and cover over a number of block courses, so would the bolts need to as long?
Would it be easier to fit the straps on the cavity side of the inner leaf before the outer leaf is completed?
Any help or solutions.
