- Joined
- 15 Dec 2019
- Messages
- 36
- Reaction score
- 0
- Country
Hi guys/gals,
I’ve recently had my building regs drawings through from my architect for a loft conversion where the truss roof is coming down and new roof put up, it states “restraint strapping - ceiling joists and rafters to be strapped to walls and gable walls, straps built into cavity across 3 timbers with noggins”
Installing these for the rafters is pretty straightforward, they would simply sit over the inner leaf into the cavity, spanning 3 rafters with noggins and a Packer. The problem is where it requires straps for the ceiling joists, especially as it’s an existing cavity wall. My thinking is that I would either have to remove a block, sit a strap in and mortar block back in. Alternatively channel out a slot in block/mortar, thick enough to slide strap in, and turn 90 degrees to hook on the inner leaf.
can I talk to my architect or BCO about using alternative strapping/fixings? Like some sort of resin anchor. Has anyone had any running’s with this instal? Or any advice from their architect?
thankyou
thankyou
