Good Morning all
Apologies for posting another Nest thread, but I've searched and can't seem to find the answer. Thank you in advance for taking the time to read.
Brief intro: Combi Boiler (Vaillant EcoTec Plus 937) and recently replaced the rubbish Honeywell wireless thermostat solution originally installed (BDR91) with a 3rd Gen Nest for the main CH control in the house. A straight swap so nice and straightforward.
We also have wet UFH in our kitchen extension on the ground floor. This has it's own Thermostat (Reliance touchscreen jobby) and is one zone I believe. This can call for heat independently from the rest of the house and often does so.
The UFH has the pump, manifold and two active valves that I can see.
Problem is that the Reliance has now broken, and I want another like a hole in the head.
So I have bought another Nest 3rd Gen to replace it.
I'm aware it's not totally ideal, but the app smarts and the fact I have another one sealed it.
However, I am struggling to get my head around how the Heat Link will be wired.
Nest is in essence a switch, and I'm replacing the existing wired 230v Thermostat, which has 3 wires going to it: L,N,L (3A) (Please see photo)
Am I right in thinking that the current wiring from the (messy) junction box to the wired Thermostat should be replaced as follows and I don't even need to touch anything there?
JN Box > Existing Thermostat
To:
JN Box > Heatlink > Nest
I have attached a diagram with the assumed wiring, does this look right?
I'm aware the temperature sensor will be surplus to requirements.
Any help gratefully received. I'll say at this point that if this is wrong or I need to open up the junction box I will employ a friendly local tradesperson ASAP. Thanks!
To:
