The builders installed my L shaped loft conversion, but not to architect diagram spec, and plasterboard was put up very quickly. So I now have the following issues. What you see in the photos is what was plasterboarded.
1) Did not tape or seal any joins. Including the light recess cut out corners you see in the image as well as the wall sockets.
2) While there is 100mm of between timber PIR. Architect diagrams had 75mm between timber and 25mm over timber, to avoid cold bridging and make it easy to make it air tight.
I informed building control, they don't see to care too much, I think the rectification is disproportional to the cost. Although they are recommending we retrofit the recess gaps, using a spray gun through the recess light holes.
I have two questions:
1) I'm trying to find the best product for those recess corners. I think I want a closed-cell, high density and low expanding foam with strong adhesive qualities. There are so many cans, most seem medium density. Any recommendations?
2) If building control don't care, I'm assuming I don't really have any recourse and just need to accept a lower quality build? Am I worrying about this too much?
