- Joined
- 27 Jan 2008
- Messages
- 29,013
- Reaction score
- 3,556
- Location
- Country
Yesterday car old Honda Jazz would not start, took other car, and on return put battery on charge, I would guess around 30 Ah, two hours at 3A and six hours at 0.8A = around 12 Ah, OK left it on charge but 0.1A is neither here or their, so it would seem either car fails to start when battery still at 50% and since all lights etc worked it is clearly not completely discharged, or battery has degraded to 50% of original, or not charging fully, however it now spins the engine over without a problem.
However in the past I have not had the option of looking on the PC and seeing how much energy has been supplied by the battery charger, so going back 50 years batteries could have failed to start cars when 50% discharged, but I simply had no way to measure it back then.
The Ah is measured as a 10 or 20 hour rate, so does not really apply to cranking, the car does 2 miles a week on average, and was not used last week, last filled tank well before Christmas, so failing to start is no surprise, but how long I should recharge for is unknown, likely some sulfation has taken place, voltage is 12.9 every time I look, but likely to remain at that as at 12.8 the charger will return to 0.8A voltage will quickly raise, then at 14.4 volts it drops again to 0.1A so 98% of time will show 12.9 volts.
So all my years of training mean nothing with this new technology, as I was taught to use a hydrometer, even if I still had one it would not help with a sealed battery. So question is at what point of its capacity will a car battery fail to start a car? Should it start at 10% or does it need 50%?
