- Joined
- 17 May 2012
- Messages
- 11,417
- Reaction score
- 1,019
- Country
I have a Baxi boiler, hot water tank in the loft of my bungalow, fed by a cold water tank in the loft. Plumber once mentioned that the pressure would be low as cold tank only slightly higher than hot water tank.
Hot water always takes ages to come through, about a minute I guess. Most pipes are in the loft, and lagged, and under loft insulation.
Even if the shower or another tap has just been used, a tap in the other bathroom is really cold to start with - not just cool, but seems as cold as the cold tap. After about a minute it warms up, but is never really hot.
Might it be that I need a new hot water tank? Or position it downstairs for better pressure? Or feed mains into it instead?
Wondering if it is just because of the low pressure that it seems worse.
Also, what would be the best way to improve the pressure?
