Mortar joint thickness at wall starter
22 Sep 2017
Hi guys, another question about my porch...
Re-building the inside wall for my porch (where the porch meets the hallway) around the door lining. Im using metal wall starters however because i cut the blocks too short my mortar joints at the edges over the wall starter are 2.5cm wide. Is this acceptable or would it make the wall too weak should i have to kick the door in? (Yes i lock myself out all the time lol). Im worried the mortar will crack.
If you won’t see it (if it’s getting rendered if it’s the outer leaf or plasterboarded over it being the inner) I wouldn’t worry too much about it.
It will be bonded (i hate plasterboard lol), if i have to boot the door in again and the mortar cracks it could come through plaster. Hoping the chances of it cracking are slim.
Ive only done 4 courses of block so far as i started late this afternoon. I could carry on with a thinner joint it just means i have to go buy more blocks and cut them.
I have a better solution that worrying about the thickness of the joint.
Use yer brain not yer size 10
Polysulphide sealant (or the latest alternative ) might be better for a joint that thick.
