Hi. Pretty sure this is a quick answer. Looking to sort this waste pipe so that it drains into the drain. Water currently goes all over as the flow is quite fast coming out. Tried changing the drain cover around but same issue. The pipe fittings at the bottom are welded so I cant adjust.
I had some spare fittings from old property, but they are 40mm floplast push fit ones. Can anyone advise where or which fittings I would need to use on this?
