Flooring difference of 20mm - Suggestions for the transition?
20 Jun 2007
London
Hi all,
Hopefully, I can get some suggestions for a little issue.
I am planning on doing the hallway floor with engineered wood. we have some samples, and realised that the transition into the lounge (which is parquet flooring) could be up to 20mm.
Any suggestions or good ideas on what could bridge a big gap with out it becoming a 'step' or an annoying trip hazzard?
Thanks in advance.
If you can't build the floor up, get a angle piece of wood (a wedge) made up from 20mm down to 0 or 3mm over the thickness of your door.
You can probably buy something ready made.
Build the lower floor up with 18mm ply or similar.
I'd rather not.. its a floor of beautiful parquet flooring from the 1950's.
maybe a wedge would be good idea. just knowing where to get it as it'd need to hang over the top of the higher flooring (not to the side) I guess, due to potential expansion of floor boards thru the year?
it needs a tapered threshold strip -when I owned a joinery shop I was always making them up for site chippies
this sort of thing:
https://www.ambiencehardwoodfloorin...wzaEkPAoaTpFP-QkbzsATapAPusEf-ToaAljUEALw_wcB
more options on ebay
thanks for the replies people.. at least I have some keywords and links I can search google with now.
As its potentially quite a height difference (20mm), ill be looking for a longer ramp so it's not so intrusive. Let's hope I can find something perfect.
I realise this is an old post, did you get a solution in the end? West end up with a similar height difference in floor and would be interested to see how yours turned out if you have any photos? Thanks
Ahh yeah an old post, and we've moved home since :) Sadly no pics
But in the end I used a wide threshold, 50mm wide and it worked. It was relatively steepish, but not too much overall.
