Paint mixing
13 Mar 2010
Tyne and Wear
I got some painting done around 6 years ago and the paint was mixed to match a Dulux colour called luscious lime. This has now been discontinued. Does the picture of the paint have any details on I can use to get the same colour mixed. There is a small amount of paint left but it's slightly a different colour when using it. I imagine this is because it is old as it seems really runny.
Kind regards
Steve
Hi Stevebuk, take the used tin of paint into most decorating centres they will be able to mix it up perfectly for you. They have a machine that will find the ral code you need. Hope this helps.
Great thanks. The only issue I have is the small remainder of paint isnt exactly the same colour as it's like water. Will they still be to work out the colour.
Steve
Steve you could take a colour chart in from six years ago they will still match the ral colour with the scanning system. You could get the ral code off Dulux if you wanted to.
