Bad pun aside....
Our hot water tap in our bathroom wouldn't switch off - I switched off the water (we have a tap in a downstairs cupboard) and took the tap apart, the washer had split, replaced it, job done, or so I thought.
A couple of weeks later, same problem, tap won't go off, take apart and washer looks fine but change anyway and works for another 2 weeks.
Now same problem again, sometimes I can get it off by turning fully on and then off again, but sometimes there's a soft thud and it switches on full while I'm turning it off.
I can try the washer again but is there any obvious reason for this?
On a suspected unrelated note, this time, turning off the water supply hasn't resulted in it completely switching off - it has slowed to a trickle but it's definitely not off.
Any suggestions appreciated - Matt
