- Joined
- 27 Jun 2018
- Messages
- 62
- Reaction score
- 0
- Country
Just a couple of points following on from what Old has said, just from a planning perspective.
If the area isn't permeable or adequately drained, you'll need planning permission for the resurfacing / regarding of the driveway.
Sloped is better IMO - if your digging out a lot of ground (a "lot" isn't a specified amount) and especially if your introducing retaining structures / elements, then you may need planning consent in its own right as the development could be considered a building / engineering operation. A slope is far less technical and probably unlikely to require consent in this regard.
Double check with the Local Authority (LA) that you don't need Planning Permission for the dropped kerb - I can't imagine you would on that street, but double check and it's usually relatively straight forward from there to get the kerb dropped with the LA.
Hi Luke thanks for all the help.
Can you see any issues with a sloped drive bearing down on the foundations just 10" below the soil?
I guess the first thing is getting a Building Control Officer around to give his thoughts. It just might be difficult at present because of the lockdown.
