Can anyone help me work out how to fix my water pressure? Property is three stories, Combi boiler on lowest floor in the kitchen. The shower at the top of the house has always been a bit flakey due to lower pressure, and this has got a bit worse recently, some days failing to trigger the boiler at all, often cutting out mid shower of out does heat up.
I can't measure pressure but flow rate in basins by the boiler/showers is as follows (l/m). Vertical distance in curly brackets {approx}.
Kitchen: cold 11.2, hot 7.7 {0m}
First floor: cold 6.6, hot 5.0 {2.5m}
Second floor: cold 3.7, hot 3.3 {4m}
I had been thinking a booster on the mains, but would that work in this situation?
Many thanks!
John
Many thanks!
John
