Around some parts sodden, but sold clay right next to the gilley..Photo from further back showing whole area may help. Water must have been going somewhere, is the surrounding soil sodden?
Not unusual for old pipes to leak, but if it wasn't connected to anything, Id expect the surrounding ground to be wet, you haven't pulled bits of broken pipe out digging?
That's a spigot end, (or piece of one), which would have been inserted into the collar of the next pipe. Joint was then made by inserting a tarred rope, and filling the joint with a strong mortar mix. Possible both mortar and rope have eroded over the years and joint simply has fallen apart.
Carefully cut the pipe somewhere around the mark, and then you can left the gulley out and get rid. Put your clay to plastic adaptor on the cut end, then see what you've got. May need a very slow bend to get you right for the rest bend, we'll see. View attachment 192068
Screwfix links are working for some reason, item numbers are, 15° bend - 69177 (as in your link above), and junction - 22348. Junction is same as you've already got, only the outlet is a spigot, which can go straight into the socket on the bend. Spigot on the other end of the bend can go straight into the coupling on the clay.
It avoids having to cut and chamfer short pieces of plastic pipe to join the fittings, and given you're tight for room, allow you to get everything in place much more easily.
I just pray this all works for you when it's done Tony!
What would be the reasons it wouldn't work? Hugh..thanksI just pray this all works for you when it's done Tony!
