How about a face and a name to your user name?
Why did you need to do that.
I'd call it using my own mind to make a decision rather than being treated like a 5 year old learning English.
There are times when the word 'require' wouldn't be an appropriate alternative to the word 'need'.
"You will need to look at this problem in a more constructive way." does not translate as, "You will require to look at this problem in a more constructive way."
If something makes perfect sense using a correct word why change it to suit the whim of another?
You have used the word Need. Try to use the word Require.
I would put that as; You are required..... or "I require you.....
It's the way words are used more so why..
Legend.: to describe someone that's real and living... Its not what I was taught at school................ I did go to school
