The meter we have has a diagram on the front showing that it's really 3off SP meters electrically - as such it doesn't matter if it's 2 or 3 phases connected, or as we have, a single phase split between two phases on the meter. Literally, just two tails from the one fuse into L1 and L2 on the meter.
Thinking a bit more, the meter wouldn't need any reconfiguring. I'd imagine the default would be to just add the phases and present one load total - how many people would be interested in the individual readings/phase ?
So for the OP, it would be as "simple" as one fuse in the head connecting to L1 in on the meter, the other fuse in the head connecting to L2 in. L1 out connects to one CU, L2 out connects to the other CU - via the contactor which can be switched by the meter. In electrical/engineering terms - trivial to do.
However, I suspect it's down as two physical supplies, and having one meter on two supplies just "can't be done, computer says no" territory.
