Honeywell CM707 replacement with Tado Smart thermostat
2 Jun 2020
I am getting confused figuring out how to wire up my Tado smart thermostat. I am replacing my old Honeywell cm707 With tado
Attaching my wiring and heating system.
thank you in advance
honewell cm707 wiring
tado smart thermostat base
I have tado AND came from Honeywell, albeit a different stat to you. Did you go through the tado guides; for me I put in the model of the boiler, the stat and the wireless receiver and it walked me through step by step, with pictures.
If your only struggle is working out what wires go in to what terminals on the tado, their guides will definitely help you with that.
A in Honeywell to Com in Tado
B in Honeywell to NO in Tado
Thank you - thats perfect. Exactly what the tado instructions asked me to do as well :)
  • Thanks
Reactions: CBW
Thank you very much. I used the tado instructions and it worked like a charm. Was panicking as i had never installed anything like this and had no prior electrical experience :)
