Hello, I decided to join the forum so I can get a bit of help.
I am looking at removing the ground floor chimney breast that is on the party wall and just want to make sure my ideas are good (always better to ask more experienced people).
The first floor chimney section was already removed years ago by the prior owners. I asked the local Building control and they are not interested if first floor was already removed and the stack is supported.
The chimney breast is 53"x 14" and the existing first floor joists are 2"x 7" at around 12" apart with a span of 3.8m, going into the part wall for support and on the other side on the exterior cavity wall(semi-detached house).
My plan is to extend the joists that sit on the chimney breast into the party wall and overlap them 3 feet with 6 M12 bolts. I looked at trimmer option and decided against it because there are 4 joist that need extending.
Is this enough or should I go 4 feet as is not a big cost difference.
Many thanks in advance for the help.
