You have to remember that the regs is a minimum standard. You can exceed the requirements.
Indeed - and that's precisely what I do.
However, many people do not seem to think beyond 'the letter of the regs', even to 'the spirit of the regs'. Whilst they may be content that the 'letter of the regs' has been satisfied by splitting lighting into two or more circuits (with different RCD/RCBO protection, which the reg does not specify), since it satisfies ...
314.1(iii) of BS7671:2018 said:
Every installation shall be divided into circuits, as necessary, to:
.... (iii) take account of hazards that may arise from the failure of a single circuit such as a lighting circuit
... I do not personally believe that it satisfies the
spirit (or common sense) of "take account of hazards that may arise from the failure of a single circuit such as a lighting circuit" - since only emergency lighting can satisfy that.
Conversely, if one has (as my house does) adequate emergency lighting installed, I believe that the installation will be compliant with 314.1(iii)
even if there is only one lighting circuit, since the "as necessary" of "divided into circuits, as necessary, to ..." becomes 'unnecessary' if that potential hazard has been addressed by the emergency lighting.
Which is what people like aptsys and I would do when planning circuits.
... and, as I've said, also me. However, as per the above, that does not mean that I feel that one always has to comply with an "as necessary" regulation when such compliance is
not "necessary" - whereas some (maybe you and/or aptsys?) seem to feel that it does.
In practice/pragmatically, of course, the main reason for "complying unnecessarily" with regs is probably to reduce the risk of problems/arguments if/when someone with limited thinking ability subsequently undertakes an inspection (e.g. EICR) of the installation!
