- Joined
- 22 Jan 2007
- Messages
- 8,526
- Reaction score
- 4,533
- Country
Have the plasterboard off the kitchen ceiling to replace with fresh stuff and be plastered.
Have some 50mm foil backed celotex still, its a 100mm deep ceiling joist, so if I fitted the celotex and taped it up for vapour barrier, that would leave 50mm air-gap behind it, is there any issue with doing that?
I should say, its 100mm ceiling joist straight to outside, no loft etc above, just felt and slate on other side of the ceiling.
Out of curiosity if you used rock-wool style loft insulation in that gap, and it took up the whole space, would it be ok aswell? Im thinking as air could still move through rock-wool just slower?
Also, the cavity wall there has no insulation in it, while there open, would it be worth pouring the cavity wall polystyrene beads down there? The kitchens an extension, but the way its built up thats the only outside wall.
