Aqua Lisa shower dripping.
2 Dec 2015
Evening,
My Aqua Lisa shower was cold so replaced the cartridge which sorted the problem.
Then it started dripping.
I hadn’t changed the o ring so popped it out and replaced it with a new one.
Still dripping!!!!!
What could be the issue?
Thanks.
Evening,
Still dripping!!!!!
Thanks.
What model?
Was the cartridge coloured?
Did you replace it with the same colour cartridge?
What model?
Thanks.
Its a Aquavalve 609 and had a grey cartridge which I replaced like for like.
I actually spoke to AL tech support, sent a picture and they confirmed the model and what cartridge I needed.
Where is it dripping from?
Morning - its dripping from the shower head......but its brand new and specced by AL. They told the model number for a replacement.
Its really frustrating !
Interesting. I replaced a grey cartridge in an Aqualisa Aquamixa yesterday and that still dripped. O ring was changed too. I've done loads of these over the years and never had a problem before. Was going to call Aqualisa after the weekend. Possible dodgy batch?
Indeed. I replaced two at once in separate showers, one was fine the other a nightmare. Wondering if I stalled it wrong but I don't see how.
The one I fitted was gravity fed and grey is the correct cartridge. I double checked because I did a like for like swap once where a combi had been installed and the cartridge hadn't been changed.
Unvented cylinders are normally pressurised to about 3 bar, when the expansion vessel goes flat or the bubble needs replenishing the pressure can rise above 3 bar and can cause taps and showers to drip, I asked for a pic as you seem unsure what you have.
Hi Gossamer,
How did you get on with the shower? I contacted Aqualisa and had a replacement cartridge sent out under warranty. Fitted and no more dripping so it looks like first cartridge was faulty.
