Drayton Digistat SCR - how to take it off the wall
4 Sep 2020
I am replacing a Drayton Digistat SCR.
How can I take it off the wall?
I tried pulling the front of it away from the wall, but it does not come away easily and I am nervous about breaking it.
Thanks,
Amnon
The Digistat and SCR are two different items. If you are wanting to change the batteries they are in the Digistat. The instructions can be found by clicking here.
it has 2 tiny screws under neath the unit, you just slacken them and it will pull off
I didn't, but as no other information was provided and as a starting point that's the most common reason for removing the cover from a Digistat... I'm sure the OP will respond if it's something else.
...wrong assumption again :whistle:
ps to @ianmcd I hadn't seen your post, you must have replied whilst I was finding the link to the Digistat / SCR instructions.
Never a problem @stem as always you were doing your best to give out great advice, I wasnt getting at your reply , I just thought I had missed something, that is all
