- Joined
- 8 Sep 2020
- Messages
- 20
- Reaction score
- 0
- Country
I recently bought a Victorian end of terrace and over lockdown have gradually been making progress with restoring it.
We ripped up the carpets in the dining room and noticed the floor boards were in a bit of a state, with some breaking away. I should also add we had the house re-wired and central heating installed. The external patio has been laid too high (it meets the bottom of the airbricks) and we're in the process of taking the slabs away from the wall and digging a bit of a drainage trench until we can afford to re-pave.
With all that said, we've noticed that the hearth itself seems to have developed a few damp patches.
We pulled up the floorboards and managed to dig out lots and lots of sand and rubble that was piled up around the edges of the room and the front of the hearth. Some of the rubble in front of the hearth included lots of chunks of slate, which I'm assuming is the damp proof course...
It also looks like the front of the fender wall has collapsed or been broken:
You can still see a bit of slate to the left of the image. At first I thought the white substance on the bricks might be mould, but having looked close I actually think it might be salt?! (There are no signs of mould on the bottom of the floorboards), though there are a few damp stains in places.
We were due to have the hearth replaced and re-tiled as well as a fireplace re-instated - does this wall need to be re-built properly?
Could that be causing the damp in the hearth?
One more bonus question that could be related -
On the other side of the room we also noticed this issue -this is directly below our under stairs cupboard where our water and gas meter are. The light grey cables are the old electrics with the darker grey cables being the newer install.
As you can see, there seems to be a rather large damp area... This looks far bigger than just a condensation issue to me, but I can't hear any evidence of running water or a leak. Do you think I should get a plumber to investigate? or is this more likely caused by something else?
Any advice on either issue would be very much appreciated...!
