- Joined
- 10 Sep 2020
- Messages
- 8
- Reaction score
- 0
- Country
Currently about to set up hive active heating with a combi boiler so bought the single channel receiver.
At present I have a Danfoss Randallset1 and a Honewell hard wired thermostat which I am going to replace however I would like confirmation that I am going to wire it correctly and was wondering if I could get some help.
Have posted pics of current setup and the hive setup that is required my question is, is what I propose correct?
5 from the Danfoss which I believe is the common to 1 on the Hive
4 from the Danfoss which I believe is Heating on to 3 on the Hive
Live and neutral same on Danfoss as Hive
Then join 1 and 3 together in a connector block where the existing stat is
Thanks in anticipation
Read more: https://www.diynot.com/diy/threads/hive-wiring.552572/#ixzz6Xfnl7GO0
