Hi everyone, firstly apologies for a question which has no doubt been asked to death on just about every forum ever. And sorry for the long post but figured better to provide the right info..
Only thing is, despite searches, I can't find answers that skirt on what I'm after. Most fish tank questions are either people wanting them in their bedrooms or potentially flats and I'm not sure my property fits either of those...
I live in a coach house (or FOG as also known), built in 2010 by Barratt Homes. It has 4 carports beneath.
I am considering upgrading to a larger aquarium, either 240 or 325ltr but I am very anxious about the weight on the floor (currently have a 185ltr plus 2 smaller tanks). Weight of a 250 tank is around 500 lbs and 325 tank is about 700lbs. Plus the stand etc etc. The 250 tank is a little over 3ft in length, the 325 is just over 4ft.
Part of me thinks the floor must be pretty robust as it supports the whole weight of the house above it, but still....
Basically : the builder cannot give me any information about construction or materials used. (Lost the plans, apparently). If you stand in the carport and look up, all that can be seen is what looks like a white plastic covering. From inside, the only area not covered in carpet or laminate is in the hall cupboards: you can see there what appears to be concrete.
Recommended placement for a tank between about 55 and 125 gallons is next to a load bearing wall, perpendicular to joists to spread the weight as evenly as possible. Problem is, I have absolutely no idea whatsoever whether I (a) have joists or not, (b) where they run if there are any, and (c) what would be above them in terms of the subfloor. So I don't know if I'd be spreading the weight, or not.
Is there anyway at all to check the floor materials etc that would not involve someone having to rip out half the flooring and then make it good?
Or am I worrying too much?
Thank you for any thoughts.
