We had a shower blowing the fuse regularly in our old fuse box with the cartridge fuses. We ended up, on the advice of a highly recommended electrician, changing to a new distribution board. I asked about the shower on the old cable and he said although he would use a larger cable if he was installing from scratch this one would be fine - he checked the shower pull cord which he said was installed badly so he sorted this out - this still stuck a lot so we leave it on - i.e. the red light is on - all the time.
The other relevant detail is the shower occasionally doesn't switch off at all - i.e. we switch it off and it is stuck on - not just takes a few seconds but won't switch off at all and we have to toggle, medium, full, medium, full, off - until it decides to go off.
However it's still tripping the power occasionally - typically when my wife has has a long and (very) hot shower - has never tripped during my quick warm showers. So my thoughts are that this cable isn't adequate and we either need to:
- have a 10mm cable installed
- switch to a lower powered shower
- get rid of electric shower and run off combi-boiler
Have I understood the situation correctly? seems like 2 is probably the quickest and cheapest option?
In case it's relevant:
We had another circuit and the RCD tripping a lot last week - we narrowed this down to a faulty washing machine and have replaced it and (touch wood) no tripping of this circuit at the moment. Fairly sure this is unrelated as the shower is on its own circuit.
