- Joined
- 27 Jan 2008
- Messages
- 28,335
- Reaction score
- 3,447
- Location
- Country
It seems with central heating analogue is replacing digital (on/off open/closed) control. The boiler turns up/down (modulates), the wall thermostat turns up/down (OpenTherm), the old motorised valve is being replaced with the wifi connected TRV head.
But does this new analogue control really work? I look at my TRV heads and so often I see this
as you can see dinning room greyed out, as to if still working not a clue, if it was sending info to control central heating rather than simply just telling me what is going on, would I have a cold dinning room when heating failed to run, of hot house when it failed to stop.
As it is I have not fully gone analogue, my old oil boiler simply switches on/off it does not modulate, so even though my Nest Gen 3 has OpenTherm my boiler doesn't so still digital (on/off) but son with gas fired boiler will I assume need to use all analogue controls which is good of course, but so many of the analogue controls seem to be wireless, with digital easy to check, turn up thermostat hear boiler start, turn down thermostat hear boiler stop, but how do you check with analogue?
My mother had a modulating boiler, and I knew it was running, but there was nothing to say if running at 20% or 100% I had not a clue if working as it should.
