New shower head will it improve the flow??
23 Feb 2020
My daughter likes to have a hot shower which we know reduces the flow of water. I have a triton 850 shower. Can I buy a different head which will improve the flow please? Really need advice she is driving me mad saying it takes agees to rinse her long hair!!!! I have read you can buy heads which will improve flow etc. We do not believe we have low pressure. Please do not suggest turning the temperature down or cutting her hair really need helpful advice.
Thanks in advance
Some do some don't. Electric showers, alonside combi boilers, are notorious for having restricted flow rates. That is why I do not have one. Mine is a vented system and the shower is pumped. The original shower head did give a good flow but it was weak and wimpy. I tried a few different heads over a period of time and eventually found a three spray pattern one from Aldi. The needle pattern digs holes in my skin which is how I like my showers. The standard pattern is also excellent. The other pattern is an aeriated one which I don't use but there is plenty of flow with it. I found that the cheaper heads seem to give a better flow than the more expensive ones and as all the shower heads are made in China it makes little difference who you buy them from apart from the price which is usually hugely inflated if you buy a branded anything.
If it is a comi boiler shower you can change the shower head, but if it is an electric shower you have to use a shower head with the same flow rate as the origional
Need more info about the shower - I've searched for "Triton 850" and Google seems to think it's either an armoured boat or a wedding ring.
If the shower is an instantaneous electric 8.5 kw ,then changing the shower head will likely make no appreciable difference to the flow ,but if it's full of limescale the Spray pattern may improve. Your shower will deliver X amount of litres per minute at a given temperature .
I'm leaning towards it being the boat
Sorry been in work all day. Right my shower is a Electric Triton 850 hand held shower. We do not have a combi boiler. My husband measured the flow rate this pm and apparently there is roughly only 3litres of water per minute at the hot setting on on the medium setting only 4 litres per minute. Obviously its my water pressure not so much the flow rate as I first thought!!! Any thoughts to help me out??
Put the shower on fully cold ,you should get 8 or 9 LTR/ min.If you do, It's not a pressure problem that you have,but the inability of the shower to heat water to the temperature that you want at a decent flow rate. Probably because one heating element in the shower has failed.
A photo would help, but as others have suggested a more powerful shower may be your only option here
For a 8.5kW shower on the full power setting and the incoming water at 10 deg, the showering temperature of 42 deg, a rise of 32 deg. the flow rate will be just slightly over 4 litres per minute.
Search for “Ecocammel Jetstorm E”.
It’s an aerating shower head that may make it feels as if there is more water.
Most aerating shower heads are not suitable for electric showers but apparently this “E” model is.
I’ve not idea if it will actually help you.
I tried an Ecocammel it was crap to be honest.
For us the problems was low water pressure, a Salamander Homeboost pump sorted that one out, our electric shower is perfectly useable now.
The shower is new :-(
