We have an unvented hot water system (megaflo) on the first floor of our property and have noticed what I can describe as a clunking noise coming from the 3 bar combination valve. This happens when the cold water is shut off on a tap (not hot water) and is more prominent on the bath taps (22mm feed as opposed to 15mm on everything else).
I have looked into the heatrae sadia combination valves and will get a g3 to change it but not sure if you need to change the whole valve or if you can change just the cartridge (which is the half the price of a new valve and less labour).
I have a video of the noise this is making below and just wanted to see if its normal or not? It seems to do it worse with the washing machine on at night and initially I thought it was water hammer so purchased a damper to go on the back of the washing machine but didn't do anything.
thanks for looking
thanks for looking
