- Joined
- 19 Nov 2020
- Messages
- 5
- Reaction score
- 0
- Country
Unfortunately I’m the owner of a spray foam roof. The survey when I bought the house didn’t flag it as an issue but soon after buying I realised it was a ticking time bomb. I should have done my research I know, but hindsight is a wonderful thing.
The loft is boarded out and has damp patches along the edges. The spray foam doesn’t extend into the eaves, only up to (I believe this is down to building regs requiring air flow/ventilation) and so the fact the damp patches extend the full length of the house on both sides of the house seem to imply this is a condensation issue. The previous owners then stuffed the eaves with fibreglass to try and sort the issue but it's clearly only partly worked.
So there seems to be two thoughts on this to try and improve my current situation:
- Seal all gaps - no warm air hitting cold surfaces around the eaves should limit condensation, at least the stuff that's visible. So probably more fibreglass insulation and spray foam to plug the gaps where the foam has shrunk.
- Add ventilation to try and get the roof functioning more like a regular one using soffit vents - presumably this could make things worse if the ventilation isn't enough.
I know the real answer long term is a reroof but that's a lot of money I don't have at the moment and I'd like to try and make the best of a bad situation. Ultimately whatever solution I do now will result in a reroof but as the roof itself appears to be in good condition, if I can get another 10 years out of it before having to do it then that seems to be the way to go.
By the way the house is 60's with felt and tiles (foam sprayed to the felt rather than the back of the tiles) so they presumably did this from an insulating point of view rather than due to a poor condition roof.
Any advice would be very welcome.
