Your initial post in this thread mentions damp floorboards, which you were asking about the need to replace them and buying a damp meter - now you are suggesting they are bone-dry. I'm confused..
Has a Wood setting
I have used a different damp meter from amazon, still a cheap tool, BUT i used mainly for comparative measurements and a damp issue we had rather than looking at the absolute number it produced. And having resolved a potential damp issue I monitored over 3 months to see if the numbers changed.
Same thing with son-in-law , and we found a small leak in the shower tray, as we were able to see the readings increase, along an ajoining wall and skirting, were it looked like the water was coming in from a different source.
Yes, they seem damp (but they are not damp to the touch)
I apologise if I am using incorrect terminology. They look like they do in the pictures but they are dry to the touch. Maybe the word to be used is "stained"?
It gives no clues about the % values to expect, but a good place to start is by testing a known to be dry section of wood which has been indoors for a few years, as a reference. Then any reading higher than that suggests moisture. I think generally is should be around 15 to 20% for dry wood.
I make good use of my damp meter, in my utility room in winter. I have a fan, dehumidifier and washing lines rigged up for clothes drying and it is always chilly in there - difficult to tell whether clothes are just cold or still damp. The meter instantly confirms which
