advice on installing insulated plasterboard
5 Dec 2012
When installing insulated board on a wall with window and door reveals, do you:
1. plasterboard wals first and window / door reveals second or
2. plasterboard window/door reveals first and wall second?
Obviously i'll need to cut the insulation off the back of one of the boards so i can butt it up to one another.
Also, because there is a boiler on the wall and i won't have enough space to fit insulated board behind the pipes, how would you deal with this situation? Would you just come as close to the pipes as possible (with the plasterboard) and leave the bare brick behind the pipes? It will be boxed in eventually once kitchen is done.
because i'll need to seal the plasterboard on this edge, would you just use expanding foam to seal it all in where the board comes to near the pipes?
cheers
I don't think it makes any difference, and yes. :D
your external corners will have beads on . so you can do them either way round or at the same time .
yep - just trying to work out which way is easier as i need to cut some insulation off the back of one of the boards to butt the other one up to it...
or, it would make life easier if i can board as oer normal board (although i assume plaster wouldn't stick to the exposed insulation on the board?
