I have a WB 8000
I’ve installed and a Bosch easy control thermostat.
a few questions
1) weather dependant control is Off by default. I was told to turn it off by WB as I don’t have a temperature sensor. So with it off will it use googled or weather?
2)what should I set the boiler target flow temp as? Does it matter given the target flow temp should be controlled by the easy control thermostat? I did notice when I set the target flow temp to 30, the heating didn’t work. Is it just the maximum?
a few questions
