Hi folks.
I’m after a bit of advice. I’m just changing the bathrooms in my house (built early 1990s) and I’ve come across strap boss connectors fitted to the soil stack for the first time. Each of the bathroom components has connections to 110mm soil pipe via a strap boss connector.
Now – one boss, for the sink, is very easily accessed (pictured), the other -for the bath - is accessed at full-arm length through the floor (not pictured - its the same except the pipe has a larger OD).
In each case, the current waste pipe (weird sizes: 35mm OD on the sink and 42mm OD on the bath) is still fitted in the boss. But in both cases they’re very wobbly, they rotate and appear to be simple push-fit insertions – which is confusing as most of the ones I’ve seen online are solvent weld. I've not disturbed them any more than that for now.
Now, I have a couple of choices and would welcome some advice.
1) If the bosses are a push fit, then the neatest thing to do is to remove the pipe, clean around the seal and then refit the completed pipework in one assembly - as I can reposition and glue them on the bench in advance ready to slide in.
2) The second option is that I can keep the existing waste stubs in situ, including their connection to the strap boss, and connect the new wastes onto these. In this case, I could either leave them alone, or I could go belt and braces and seal around the outside of the joint with Plumber’s Gold or a similar silicone sealant.
The risk is that these will not be accessible after the bathroom is fitted, so I need to be certain that these will be leak free (and airtight on the top as they go straight into the main soil pipe). A leak at this point would cost a lot of money to put right once the bathroom is fitted.
Could anyone advise the safest approach (including “just leave it alone”) for me to tackle this? I’ve fitted plenty of waste pipes before (compression and push-fit), but haven’t yet done any solvent welding nor have I ever dealt with a strap boss.
Thank you.
Thank you.
